toomanymodz
- Oct 14, 2009
I used these only a few hundred miles. New they run $125. I'll let these go for only $75.
These are very popular for mild street builds. Specs are:
OD Outer: 1.244
ID Outer: 0.860
Damper: Yes
ID Inner: 0.770
Installed Height (Valve Closed): 125 @ 1.750
Open Load (Valve Open): 350 @ 1.250
Spring Rate: 450
Max Coil Bind: 1.100
Max Lift: 0.550
OD Outer: 1.244
ID Outer: 0.860
Damper: Yes
ID Inner: 0.770
Spring Rate: 450
Max Lift: 0.550
