toomanymodz
- Oct 14, 2009
Slightly used. Only 600 street miles on these, never to the track. $100 shipped.
PAC Racing Springs offer superior performance, durability and value for turbo Buick V6 applications.
These valve springs are ideal for turbo Buicks running a mild roller cam at low RPMs (under 5500).
Specifications:
OD Outer: 1.244
ID Outer: 0.860
Damper: Yes
ID Inner: 0.770
Installed Height (Valve Closed): 125 @ 1.750
Open Load (Valve Open): 350 @ 1.250
Spring Rate: 450
Max Coil Bind: 1.100
Max Lift: 0.550
Part Number: PAC 1200-12
Specifications:
OD Outer: 1.244
ID Outer: 0.860
Damper: Yes
ID Inner: 0.770
Spring Rate: 450
Max Lift: 0.550
