I had been battling the same exact issue . Replaced whole fuel system with new walbro 430 pump and new larger lines . Problem went away . Now I'm having a issue with the TPS not going over 3. V wot . I used the 5v power from the TPS to power fuel transducer . I am in the middle of checking the 5v from the ECM . Also all my connections where not soldered . The acufab fpr I rebuilt and has been fine ever since. Of course I didn't discover the TPS issue till I was on a Dyno :-( car would not go past 5k .attached is my weird Dyno sheet . I believe the Dyno was set up completely wrong . 343 hp ?? and 640tq ??? . Sorry to high jack . But would check for 5v from ECM ,fuse able links , ect
