Jerryl
Tall Unvaccinated Chinese Guy
- Dec 14, 2004
Anyone have an idea of the time period the design change was implemented with the A-F regulator?
SignUp Now!Interesting Steve...
Have you ever switched regulators car to car?
Rick
Agreed. The ability to log fp is also the reason many cars are not blown up, and going faster than ever. The real question in my mind is: What variation of fp is acceptable based on the hp level?From what I can tell, the Accufab unit has had a great reputation all these years..... When there was no powerlogger to track how choppy the pressure regulation is. Now that anybody with a PL and a transducer can witness how crappy the pressure is, I have feeling they won't be as well liked as time goes by.
Granted, that's just what I've seen with my own two eyes.
Thanks for posting Steve. My intent is to post back to back logs showing the difference is between the Accufab and the Kirban unit, once it arrives. What are your smoothing settings set to in the logs you posted? For now, I have everything turned to "None" but if I bumped it up to "Heavy," the line would certainly smooth out.
I believe it matters if you shut down and your fuel pressure bleeds down fast you might have one of your fuel injector is leakingDon't mean to hijack, but I have to ask a legitimate question on this subject. Who cares or why does it matter if our fuel pressure bleeds down at key off? The pump primes anyway. As long as your regulator holds desired pressure during operation, it really shouldn't matter right?
I guess I should've worded more carefully. Understood on an injector leaking, but who cares if the regulator bleeds the pressure down.I believe it matters if you shut down and your fuel pressure bleeds down fast you might have one of your fuel injector is leaking
That is the one I use also , now you know , good threadKirban FPR
