forcefed3.8's
Buckeye Bullet
- May 26, 2002
I use etch primer, and not the stuff in the spray can.
SignUp Now!I-car says filler is usually applied over bare metal. It can be applied over epoxy, but follow the filler manufacturer's instrustions. This is an old technique that some still use. I started doing bodywork in 1996, and I was never taught this. My car looks just as good as it did when I restored it in 2006. I am i-car platinum and am a role rep for a high end shop in NE OH.(The paint companies dont recommend using filler over it anymore either, that is an old 1990s) Toyota still requires this before filler is applied on their cars per ICAR standards.
Have you taken the Toyota Icar class yet then? They require epoxy first and do not allow self etch anywhere on the car. I was platinum but they changed things up and I no longer kept it.I-car says filler is usually applied over bare metal. It can be applied over epoxy, but follow the filler manufacturer's instrustions. This is an old technique that some still use. I started doing bodywork in 1996, and I was never taught this. My car looks just as good as it did when I restored it in 2006. I am i-car platinum and am a role rep for a high end shop in NE OH.
What shop do you work for. Looking to get my GN paintedYou need to sand the primer to make it smooth. It will look like crap if it isnt sanded.
If you are in the NE OH area, PM me for recommendations. The shop I work at does not take in resto work. We do strickly collision.What shop do you work for. Looking to get my GN painted
