Painted !
larrym
West Coast Newfy
Its been a winding road but i shot my car on the weekend, not bad for a rookie :D
Shaw Photo Share
Here is a link to my paint progress from strip down to paint.
Good forum for paint and body work.
Body day 1
From what i could see, looks pretty good..Would have pulled the 1/4 glass though. Props to you!!:smile:
GC
I just left the windsheild and rear window in all the rest came out.
Even the door glass(had to swap a door out)
Went back and looked again...guess my old eyes deceived me..LOL!:frown:
GC
nice work. see my slide show i did almost the same thing. Did you have rust repair?
I know its a little late, but did you add a flex agent to the paint for the fillers? The paint will crack if you didn't. :frown:
I asked about that :confused: I was told that it wouldn't be required on this paint. I still have enough to paint them again if need be.
I used a single stage Nasons fulthane.
You should be fine...They don't flex that much, unless hard impact on the bumpers,then you have other problems as well... .You can spray an aluminum test panel and bend it almost in half and the paint is still intact. Yes, I have done it with the Nason's ful-thane to check it out for myself..it's a reasonable cost paint line, IMO
GC
Flex agent is put in the paint for assembly if the part is painted off of the car. It's effect is gone from the paint within a couple of days after cure.
