painting intercooler?
oliver12
i removed the intercooler to clean i figure while its out ill throw some paint on it. anyone ever done it? what type of paint? or high temp needed?
High temp for sure will be your best bet to last a long time. VHT black at a auto parts store
Stripped mine completely. . Refinshed fins with hightemp flat black.. necks and ends with high temp gloss
I got my innercooled in my WE4 powder coated gloss black looks really nice. For my front mount I had the unit blasted at my coaters and painted it with extreme chassis black from Eastwood.
Wanna say I used bar-bq grill paint. Cant remember the manufactuer... krylon? It has held up nice from what I can see
Cleaned up the shroud while I had it out
Painting or coating coolers of any kind inhibit them from dissipating heat.
hello people; Just curious when you cleaned your IC was there alot of crap inside of it??
IBBY
Garrett must not have known. They paint ed thousands of them:rolleyes:
If your painting a stock innercooler who cares about heat dissipation. If your using one your probably not racing or blowing the pants off of anybody in the first place.
i had a little oil but not too much. used that purple degreaser, then i hooked the vacuum to it and let it run till no water came out. i appreciate the replies gonna stop at the store today and pick up some vht and rattle can it.
They actually make a thermal dispersing coating. That promotes heat transfer.
Yes! If your going to paint it use the correct materials. If your not worried about dissipating heat take the IC off and save some weight!!
