May 31, 2006 #1 9 9SECVSIX Member Joined May 25, 2001 Messages 520 what are the trans pan gasket options other than the cork ones? I think the factory used a hard paper type gasket Thanks 9sec.
May 31, 2006 #2 jpwalt1987 Well-Known Member Joined Nov 9, 2003 Messages 1,885 a thin bead of "the right stuff" is the only way i can keep mine from leaking.
May 31, 2006 #3 C chris718 Active Member Joined Dec 10, 2002 Messages 5,356 use the farpak gasket and torque the bolts to 160 175 inch pounds after verifying pan and case are free of debris and flat
