Part Number requests....
Spdrcer34
What is the part number for the spring isolator that goes on the TOP of the Front Springs? Does Moog or GM make one?
What is the part number for the 36mm Hollow Sway bar, and the bushings? Do you use the G-body bushing 'shell' with the F-body 36mm bushing? Or do you need to use a F-body 'shell' with the bushing?
Ryan
Okay, I think I found the part numbers for the 36mm bar and bushings, can anyone VERIFY these are correct?
#14094344 for the bar, $73.47 on GMpartsdirect
#14094389 for the bushings, $9.89 on GMpartsdirect
If that is the correct number for the bushing, are they sold as a PAIR or individually?
Ryan
Can not verify part #'s but, have you tried
partszoneonline.com for prices this is a GM dealership out of PA. And they are cheaper than most on alot of items.
You can not use the bushing shell from the f-body becuase the bolt holes are "offset". The G-body users straight bushings.
All of the part numbers are discussed in the "junk yard dog" section.
Upper spring insulators GM part number 15597425. Yes those are the correct numbers on the bar and bushings.
