OneLethal87GN
R.I.P. Lethal GN
- May 26, 2001
I have a two part problem. First, I get around 4.5 degrees of knock under part throttle and about 5 psi. When I give it more gas and boost the knock goes away. The torque strap is very tight and the engine doesn't rock when I push on it. I've been using 87 octane but rule that out since the knock almost is always 4.5 degrees. I will be switching back to 93 soon. The other thing I've noticed is my car seems more powerful going quickly into throttle rather than stomping it and going WOT instantly. I usually try this halfway through second gear so it won't drop down into first. Going WOT just don't feel as strong as it should. It feels stronger giving it gas quickly. What I mean is going from 1/8 throttle to 3/4 throttle in about 2 seconds. I know I need a new era chip since the old MM chip and K-B race chip are old tech. The car does need to be tuned as well but isn't far off. Any ideas on the part throttle knock or why WOT feels weaker than a quick throttle would be very helpful in seeking out these gremlins. Thanks in advance.
