Part with prices....
wickedsixx
NOS PARTS
Accumulator Ball 18038507 $190 shipped
Intake pan gasket 12328760 $30 shipped
(3) Head gasket 25528486 $45 shipped per gasket
Coil pack 12353801 $85 shipped
Knock sensor 10456287 $35 shipped
(6) 42TS Delco Spark Plugs $10 shipped
3.8 SFI Emblem 25519633 $30 shipped
Boost Line Y kit $30 shipped
Down Pipe to Elbow Bolts with Springs $20 shipped
NEW AFTER MARKET PARTS
Rol Extreme Cork Rubber Valve Cover Gaskets $10 shipped
Felpro Timing Cover and Water Pump Gaskets $10 shipped
Energy Suspension Poly Front Control Arm Bushings $30 shipped
Down Pipe to Elbow Gasket $15 shipped
USED AFTER MARKET PARTS
Solid rocker shafts $80 shipped
adjustable pushrods $80 shipped
USED 86-87 PARTS
Stock ECM Chip $20 shipped
(7) 2 dot Rods $70 shipped
Turbo Shield $30 shipped
Intercooler $80 shipped
Intercooler Shroud $45 shipped
Aluminum Drums $65 shipped
Lower intake clean and repainted $160 shipped
Plenum $30 shipped
Plenum and Throttle Body $100 shipped
Throttle Cable Bracket $20 shipped
Flat Coil Bracket $30 shipped
Round Coil Bracket $25 shipped
Fuel Rail w 233 reg $45 shipped
Coil Pack $35 shipped
Coil Pack Module $35 shipped
(2 )Belt Tensioners $45 shipped
84-85 PARTS Make offers.
Stock Block clean
Heads
Intake Manifold clean and repainted
Brackets
Sensors
Engine Harness
Down Pipe
Up Pipe
Complete Turbo
Fuel Rail
Turbo Adapter
Throttle Body
84-85 GM Wheels with 215/65/15BFG on front and 235/60/15 Dragradials on back
5 passes and approximately 100 miles on all tires $350 plus shipping
Newer GTA/GNX Wheels 245/50/16 Firestones 95% front 45% back with caps
and chrome lugs $700 plus shipping.
Pm or email me for pics and yes I take pay pal add 3%
Thanks...Shawn
updated list
NOS PARTS
rjc power plate for stock plenum $45 shipped
USED 86-87 PARTS
Plenum $30 shipped
Stock Block clean
Heads
Brackets
Sensors
Down Pipe
Up Pipe
Complete Turbo
Fuel Rail
Turbo Adapter
Throttle Body
2- 215/65/15 BFGs about 100 miles
235/60/15 Dragradials 1/2 tread left
Thanks...Shawn
ttt
NOS PARTS
USED 86-87 PARTS
Plenum $30 shipped
Stock Block clean
Heads
Brackets
Sensors
Down Pipe
Up Pipe
Complete Turbo
Fuel Rail
Turbo Adapter
Throttle Body
Thanks...Shawn
drums
i said i will take the drums but havent heard from you.but i also see that they are not in the updated parts list.still available?
NOS PARTS
Intake pan gasket 12328760 $25 shipped
chrome maf pipe $45 shipped
USED 86-87 PARTS
aluminum drums $100 shipped
Plenum $30 shipped
Stock Block clean
Heads
Brackets
Sensors
Down Pipe
Up Pipe
Complete Turbo
Fuel Rail
Turbo Adapter
Throttle Body
Thanks...Shawn
drums
sent you an email in response for the drums.i'll take them.65.00 shipped as stated.thanks
