m3x1c0
Bad luck Buick
- Jun 16, 2014
front bumper? header panel?
SignUp Now!The header panel wasn't to bad untill I broke one of the mounting studs being the battery area. I'm not sure if anyone would want it nowheader panel with turn signals and bezels
The power master may be taken. I will let you know this weekend if I still have it.Im looking for a broken/cheap powermaster unit that is complete that I can make a cutaway demo with.
I'll check the front bumper. One of the bumpers was a chrome bumper someone painted black and if I remember it may have been tweeked just a little on one side. I'll check for youfront bumper? header panel?
will you post a pic of itThe header panel wasn't to bad untill I broke one of the mounting studs being the battery area. I'm not sure if anyone would want it now
I should still have that. I think it's still on the body. I will check tomorrowHow about the throttle cable.
Did you find the throttle cable? How much do you want for it?I should still have that. I think it's still on the body. I will check tomorrow
I dont want to ship anything at the moment expecially the big stuff like the header panel.how much do you want for the header panel and do you have the headlamp bezels and turn signals
I havent had a chance to look at the throttle cable yet. Its been raining for a couple days and the shell of a car is sitting outside. Im sure its still on the shell. I will look when i get a chanceDid you find the throttle cable? How much do you want for it?
I think I have the trunk trim as long as I didnt bend it. Turbo heat shield is missing. I know I have the front wheel well trim and I think the rear is there but I has been modified when someone rolled the rear fender lip. I have used air deflectors but one has a cold air scoop installed on it. Im not sure what part you refuring to with the package tray. If its the metal rear deck lid where the speakers mount then no I dont have that. I cut it out for my other car. Since your semi local let me know if your interested in anything so I can unload as much stuff as you want to clear out my garage.Do you by any chance have the trunk lid rear edge trim, turbo heat shield, air deflectors, package tray or the wheel well trim. Please let me know, I am about an hour away from you btw.
How much for the air deflectors, I don't mind that it has the cutout, I plan on doing that anyway...lolI think I have the trunk trim as long as I didnt bend it. Turbo heat shield is missing. I know I have the front wheel well trim and I think the rear is there but I has been modified when someone rolled the rear fender lip. I have used air deflectors but one has a cold air scoop installed on it. Im not sure what part you refuring to with the package tray. If its the metal rear deck lid where the speakers mount then no I dont have that. I cut it out for my other car. Since your semi local let me know if your interested in anything so I can unload as much stuff as you want to clear out my garage.
