PARTING ANOTHER PARTS CAR,87 T-TYPE, PLUS BIG LIST OD PARTS,(Jan.04th)
Intercooled88s
Moderator
New Parts added to list
87 Grey T-type seats(front and rear in very nice condition) $300
Grey seat belt set(10 pieces) $60
Grey console $100
Grey concert sound 2 lower door panels $100
Grey upper door panels in nice condition missing chrome strips $80
Grey steering column $120
Grey steering wheel in excellent condition(not redyed or recovered) with horn ring $300
Grey dash pad no cracks $100
Analog gauge cluster $50
Vacuum brakes with pedal $65
PowerMaster good as a core its complete but I dont know what is wrong with it $60 has accum and switch still there
PowerMaster to firewall adaptor(bracket) $30
87 grill $90
87 GRILL CUT FOR FRONT MOUNT $45
84-87 T-type header panel $150(GM)
Front and rear alum bumper reinforcements Front $100 or rear $80
Tail lights with blackout trim $100
Quarter windows with blackout trim $100 for both sides
Windshield blackout trim $40
Rear window blackout trim $30
Turbo harmonic balancer $70
Turbo crank std/std $300
86-87 Fuel rail $50
Intercooler fan $45
009 inject $150 low miles
Drivers side header, rewelded $50
87 ECM $50
Cam position sensor with cap $70
Tranny cooler $20
87 GN seats front and rear in great condition $500
87 GN Front bucket seats need recovering $150
86-87 GN locking T-tops $150 a set
Misc.
BRF valvebody $200
GN rearend(8.5 non posi , drum to drum withdriveshaft ) $500
Driveshaft for 8.5 rearend $50
Transmission cross member $40
BQ coded GN transmission 48k $300
BRF tranny $500
Stock 200 4r tranny pan $30
86-87 GN wheels good for cores all 4 for $120
INTERIOR
Steering column(floor shift) $120
85-87 Gn Steering wheel(good to have recovered) $50
85-87 GN console $140
Plate on console that goes around the shifter $40
84-87 GN shifter $35(needs T handle)
86-87 GN seats $400
86-87 GN lower door panels $60
Grey rear sail panels(panels around the quarter windows) for t-top car in great condition
$40 for both
Grey Third brake light $25
85-87 GN seat belt set(10 pieces) $70
I have all the plastic interior pieces for a marroon or grey car with either t-tops or hard
top .
Nice grey arm rests $15 for both
Nice blue passenger visor with lighted mirror $25
Map light $20
Gauge surround $35
radio surround $25
Stock GN radio $50
Maroon dash pad $110
Blue dash pad $120
Grey dash pad $110
Light sage green arm rests(these are the rare light green color) $40 for both
Light sage green seat belt guides $25 for both
Light sage green seat belt upper bolt cover, triangular shaped trim piece $20 for both
T-TOP trim around the t-tops on the inside of the car in Red, Maroon, or grey , all 6
pieces
$100
ENGINE PARTS:
84-85 valvebody with TPS,IAC motor,vacuum manifold $50
stock 86 chip $30
stock 84 chip $20
86-87 Turbo $150
86-87 Turbo can be used as a core $75
84-87 Turbo elbow $25
86-87 MAF $80
85-85 ECM $40
86-87 ECM $70
Engine frame mounts $35
86-87 oil return to block, brass adapter,screws into block in front $20
86-87 Throttle bracket $35
Intercooler brackets both for $50
underdrive pulleys(crank and alt) $40
86-87 Crank pulley with adapter $30
86-87 dipstick and tube $40
86-87 Factory Oilfiller tube and cap $30
86-87 Scoop for airbreather $20
109 Block $300
stock 8445 heads needing rebuild $40 a set
86-87 Lower intake manifold $130
84-85 GN intake $40
84-85 fuel rail $25
Any year injector harness $35
84-85 valve covers $35
86-87 valve covers $35
cam position sensor just the lower part(no cap) $30
86-87 MAF $100
84-85 MAF $45
84-85 AC compressor $40
86-87 AC compressor $60
84-85 Alt $35
84-85 turbo adaptor $25
84-85 crossover pipe $35
84-85 engine wire harness $100
86-87 engine wire harness $150 HAS SOME REPAIRS BUT WORKS GOOD
Any other harness on the car e mail I have them all
86-87 Power steering pump $60
86-87 Belt tensioner $70
86-87 Alt. $60
86-87 Main accessory Bracket $70
84-85 Main accessory Bracket $50
Small plastic guide that holds the posi bat cable to the lower front cover $20
84/85 to 86/87 conversion parts(all the original GN parts you need to convert over from 85
to 87) $1400
Oil cooler adaptor with nut $35
Timing cover $30
Turbo rods(2 dot) $40 a set of 6
Turbo flex plate $25
Turbo oil pans $35 each
84-85 control module $50
84-85 coil pack $40
Body & Misc.
mast for manual antenna $30
84 Hydrobooster brakes $100
PowerMaster brakes assembly $200
Vacuum brake assembly +pedal $65
GN steering box $40
GN rear bumper $100
Alum. rear bumper reinforcement $80
86 GN grill $90
85 GN grill $60
85-87 T-type grill emblem $20
84-87 GN fenders(GM) $80 each
Non Key locking t-top $90+shipping for the set
T-top bags $35
Lock set(all 3 locks with key) $60
Drivers mirror $20
Passenger remote mirror $40
Blackout door handles $15 for both
Black wheel well trim $40 each
Turbo plastic wheel wells $80 each
Any other blackout piece e mail me I have them all
GN hood $95-$150
AC lines $45
Fuel pump hanger/sender $50
Turbo gas tank $40 wont ship
GN sway bars $30 each
windshield wiper assembly $15
Complete heater box $100
E mail me at Fortune628@aol.com or Bobhebert574@aol.com
My phone # is 413 746 9668 I rarely check my voice mail so if you call and dont get me try again later. E mail is quickest to contact me.
Are the upper grey door panels the same as an 87 GN? If so do you have pics? I need them. Thanks!
do you happen to have headers you are gitting rid of if so pm me and let me know how much. Thanks......
You list 2- 87 MAF's 1 is $100 & 1 is $80 Why the cost difference?
Amount of miles on them?? Thanks!
Just a Six??
The $100 was a original GM MAF and the $80 was a Reman. GM one is gone. I should have made it clearer.
pm sent
pm sent, also interested in the 009's put me inline for those too., alon with the floor shifter Thanks
