Parting out 85 motor
imjoesnuffy
I just break stuff!
Hey guys and gals,
Figuired I'd give you guys first shot at this stuff. I have everything but a good crank and turbo. Turbo could be used as a core. Pics upon request, but might take me some time to get them to you due to the motor being located elsewhere. Will take best offer on everything, except for the headers.
Just about everything has 117k on it, unless otherwise noted. Motor was rebuilt at sometime or another but don't have specifics.
Hot Air block, 85 20 Bolt oil pan
8445 Heads stock
Stock connecting rods with pistons
Intake
IAC
TPS
Stock injectors 117K
Fuel rail
Stock 85 MAF
85 Coil and ignition
85 ECM with chip
Big Mouth Cold Air Intake, 3K miles
TPS TEC, 3k miles
All pulleys
AC Components
Ceramic coated Headers, up pipe, beginning of a downpipe, crossover, never been used. Not sure of the manufacturer, $500
Stock Throttle body
Selling this motor due to going to an 87 setup. See the thread, "Oh the Horror" in the Hot Air section. Motor is fine except for the crank and turbo. Everything is located at zip 40037.
I'm interested in your Big Mouth Cold Air intake and the IAC, how much for both? Did you buy the intake from turbogn? Any pictures?
Shipping would be to 27265.
Tps
Brad I will let the whole Throttle body with TPS, IAC, vacuum block and Whatever else is bolted on there go for $45 plus shipping $8 parcel post thru USPS to you.
Just the TPS shipped to you $20 sound OK?
If brad just wants the TPS, I'll take the rest of the throttle body.
Eric
parts
OK Brad gets the TPS.
Eric gets the cold air kit and the rest of the throttle body. It has the stock plastic vacuum block on it.
You guys can paypal me or send check or money order, doesn't matter to me. I'll PM you my info. Don't really have time to get back to the garage until Thurs or Friday. If you want to wait until then thats fine too.
Ttt
Moving this to the main Parts for sale section if no one else is interested.
TTT
