Parts at Bowling Green
chris
Parts that will be at Bowling Green.
Large parts pre-pay since I'm limited on space to transport.
8445 heads - $50 set - sold
2004R transmission - fresh rebuild by DynoTech, only driven less than 5 miles and 2 qtr mile passes. NLU with deep pan. $950 - sold
Torque Converters for 2004R -
PTC 20 blade NLU - good for big power and higher RPM's - $825
Vigilante LU single disc, 3600 stall - low miles - $400
Unknow brand NLU -10" - $175
SpoolFool front and rear fillers - new - $600 - sold
Fiberglass front bumper - new, from Kirban - $150 - sold
PowerLogger and stock ECM - $300
Large aluminum radiator -16an fitting welded, stock size with trans cooler only - $300
Dynamic EFI system with low impedance driver box - $650
Stock intake, bare, ported with oblonged mounting holes, welded EGR - $125 - sold
MT drag radials, new - 295-50-16 - $400
Stock turbo cranks, assortment - will need cleaned and possibly turned - $150 each - sold
Turbo 400 transmission out of 73 grand prix, short tail shaft, stock with 83k miles - $400
Accufab AFP regulator - $90
Inner cooler fans - $50 each
ATR front mount inner cooler - $450
Stock inner coolers -
clean ported, bare - $125
dirty with up pipe and shroud - $75
Underdrive pulley - $50
8.5 vector rims, includes centercaps - nice condition - $400 - sold
Factory headers - repaired - $200 - sold
Factory headers - need repaired - $100
Factory header modified for external wastegate - $100
Factory crossover pipes - $50
Remote oil system adaptor, lines, filter housing - $100
Drag tire tubes - $50
Factory streering box, 92k miles - $100
Manual S-10 steering box - $100
Factory tensioner - $100 - sold
TB, doghouse, steel vacuum line - $100 - sold
Fuel rails - $50
Throttle bracket and coil pack bracket, chrome - $100 - sold
Coil pack plate - $35
Champion head clamps - $75
Piston press for stock pistons - $200
GN center caps - used set of 4 - $100 - sold
GN center caps missing turbo 6 emblem - $10 each - sold
Pics and more parts to come.
Prefer to deliver large parts to BG.
Buyer responsible for shipping fees.
Does the factory header that is welded for an external WG come with both headers and crossover, or just the passenger header?
What kind of WG is it setup for? V-band style?
