Eric Stauch
Nasty87
- Jan 12, 2008
Hello everyone, I have for sale a few parts laying around. All prices are NOT including shipping and if paying with PayPal please add 3% for the fee, but I will also accept a postal money order. Thank you all.
PLEASE PM ME REGARDING ALL TRANSACTIONS INSTEAD OF POSTING REPLYS, IT HELPS KEEP TRACK OF WHO WAS FIRST.
One pair of black rear wheel well opening trim- $40
http://i628.photobucket.com/albums/uu9/thenasty87/IMG_20101019_203006.jpg
Power master bracket, the part that bolts to the fire wall- $10
http://i628.photobucket.com/albums/uu9/thenasty87/IMG_20101019_203056.jpg
Washer fluid tank, would clean up but has extra fiting tapped in lid- $3
http://i628.photobucket.com/albums/uu9/thenasty87/IMG_20101019_203118.jpg
Stock 200-4r pan with original hardware, the two bolts where the shift cable bracket bolt up are different- $20
http://i628.photobucket.com/albums/uu9/thenasty87/IMG_20101019_203214.jpg
Evap purge solenoid- FREE (pay shipping)
http://i628.photobucket.com/albums/uu9/thenasty87/IMG_20101019_203239.jpg
Greaddy knock off blow off valve, worked fine- $10
http://i628.photobucket.com/albums/uu9/thenasty87/IMG_20101019_203246.jpg
Factory crank pulley powder coated silver- $5
http://i628.photobucket.com/albums/uu9/thenasty87/IMG_20101019_203254.jpg
Stock camshaft, great shape- $5
http://i628.photobucket.com/albums/uu9/thenasty87/IMG_20101102_203515.jpg
Mass air flow adapter to hook to five wire delco- $3
http://i628.photobucket.com/albums/uu9/thenasty87/IMG_20101102_203535.jpg
Stock valve springs, with locks and retainers- $5
http://i628.photobucket.com/albums/uu9/thenasty87/IMG_20101102_203546.jpg
Sun visor hardwear, no screws what you see is what you get- FREE (pay shipping)
http://i628.photobucket.com/albums/uu9/thenasty87/IMG_20101102_203601.jpg
Valve stem seals, six positive style six umbrella style- $3
http://i628.photobucket.com/albums/uu9/thenasty87/IMG_20101102_203631.jpg
Double roller timing set nearly new no crank gear- FREE (pay shipping)
http://i628.photobucket.com/albums/uu9/thenasty87/IMG_20101102_203637.jpg
Under drive crank pulley fan hub- $3
http://i628.photobucket.com/albums/uu9/thenasty87/IMG_20101102_203704.jpg
Stock injectors, worked fine just upgraded to 42's- $20
http://i628.photobucket.com/albums/uu9/thenasty87/IMG_20101102_203744.jpg
Rear drum brake upgrade, S10 wheel cylinders and 4 long buick shoes- $15
http://i628.photobucket.com/albums/uu9/thenasty87/IMG_20101102_203850.jpg
http://i628.photobucket.com/albums/uu9/thenasty87/IMG_20101102_204021.jpg
New A/C dryer- $7
http://i628.photobucket.com/albums/uu9/thenasty87/IMG_20101102_203913.jpg
Black door edge molding, has some notches in them, may be direct fits? (in other words not universal, they came off my 87GN)- $3
http://i628.photobucket.com/albums/uu9/thenasty87/IMG_20101102_203939.jpg
Jute that goes between door pannel and door, I give them a 8 out of 10- $15
http://i628.photobucket.com/albums/uu9/thenasty87/IMG_20101102_204057.jpg
C5 Corvette front rotors, brand new Wagner brand never been used, great for a brake upgrade, one right and one left, only taken out of plastic for picture, these are around 90 a peice new- $75 for both
http://i628.photobucket.com/albums/uu9/thenasty87/IMG_20101102_205453.jpg
http://i628.photobucket.com/albums/uu9/thenasty87/IMG_20101102_205524.jpg
Series II coil set up, brand new delco module and delco coils, this is a great upgrade and simple. ten minutes to bolt on better idle and high RPM spark. will work with stock plug wires, may have to move them around for example your number 3 wire may now be number 5, ive done this with my car- $175 (the delco module is over $200!!)
http://i628.photobucket.com/albums/uu9/thenasty87/IMG_20101031_130943.jpg
http://i628.photobucket.com/albums/uu9/thenasty87/IMG_20101102_204557.jpg
http://i628.photobucket.com/albums/uu9/thenasty87/IMG_20101102_204536.jpg
http://i628.photobucket.com/albums/uu9/thenasty87/IMG_20101102_205350.jpg
New A/C dryer- $7
