Updated list:
1. Black trim: One set of headlight bezels
Drivers A pillar
Passenger and Drivers drip rail
Rear window (right side riser)
One Set of Wiper Arms
Passenger Door Handle
2. Chrome trim : One Set of Wiper Arms
Front Window Risers (both sides)
Set of door locks with Keys
3. Stock Turbo Crank STD/STD but will need to go 10/10
5. Front Air Dam (drivers side)
6. 4 spd shifter assy (needs new or HD j-rod)
7. K+N style filter 3.5" opening
10. Stock Up Pipe
11. Tensioner Pulleys (2)
12. Stock wastegate actuators (non adjustable (2))
13. TV Cable (Hot Air)
14. Trans DipStick (one Hot Air)
15. Power Steering lines
16. Crank Sensor and bracket (Hot Air)
17. 86-87 Hard Vacuum Lines (front set (2))
18. Chrome Bumperrettes (4 front, one rear)
19. Drivers Remote Mirror
20. Negative battery cable
21. 86-87 Throttle Body, almost complete with sensors (needs different throtte cable bracket though)
23. IC Brackets (2 drivers, 2 passenger)
24. Taillight Harness (86-87)
25. Body harness (fuse block to taillight)
26. Vapor canaster with sensor
27. Stock Air box (lower half only) also 2 mounts
30. HVAC box top vent piece
31. Antenna Wiring harness (power)
32. Two Power Antennas, need fix kit installed
33. Fuel Rail (86-87)
34. EGR Covers (black and chrome ones!)
35. T Top metal trim retainers (both sides, L shaped pieces that go under the glass
36. Brake Pedal (powermaster)
37. 87 T wheels with new tires (VERY NICE)
38. Rear Bumper Gaurds (2)
39. Aluminum Bumper Support (rear)
40. Rear Trunk Fillers (between rear glass and trunk lid, one for hardtop, one for vynal)
41. Sail Panel Carpet inserts (set, Grey T Type)
