Parts Going to BPG
Buicksx2
RCA: Home of the The Jack
I will be taking these parts with the exception of the GN drivetrain to BPG this week. We will be pitted in the JCC tent area along with the MAGNA gang and the Canadian Crew. Stop by and say Hi and look at some parts.
6776 PRECISION BALL BEARING TURBO $775
AKLYCONTROL AKLY KIT WITH CHROME UPPIPE $325
1 PAIR BRAND NEW PPG WINDOW GLASS FOR 87 REGAL $125
87 GN DRIVETRAIN – ALL STOCK 44,000 MILES– COMPLETE INCLUDES EVERYTHING INCLUDING WIRING HARNESS, ALL BRACKETS AND TRANS CROSSMEMBER $3000 – SEE OR EMAIL ME FOR FURTHER DETAILS
TWO STOCK INTAKES – NOT PORTED $125 A PIECE
SNAP ON MT 418 PRIMARY TACH DWELL MACHINE BRAND NEW NEVER USED $45
SNAP ON MT 402 ALT/GEN/REG TESTER BRAND NEW NEVER USED $45
TWO SETS CRANE 8MM FIREWIRE WIRES NEVER USED $35 A SET
ONE 2/58 AUTOMETER LIQUID FILLED 0-35 PSI BOOST GAUGE $25
ONE VDO EGT GAUGE – THERMOCOUPLER BROKE $20
MOROSO ROUND TRANS COOLER $20
GENERIC USED TRANS COOLER $15
FEL PRO HEAD BOLT SET ES74022 $25
ONE PS AND ONE DS SIDE VIEW MIRRORS – NEED PAINT $20 FOR PAIR
ATR CANISTER RELOCATION BRACKET $25
ONE STOCK CAM USED - $25
ONE PERMACOOL TRANS/OIL COOLER WITH FAN $50
ONE POWER STEERING DELETE PULLEY $45
TWO SMALLER PERMACOOL 12VOLT FANS $20 A PIECE
SUMMIT RACING TACH 0-8000 WITH INCORPORATED SHIFT LIGHT $25
AUTO METER TACH 0-8000 WITH INCORPORATED SHIFT LIGHT $25
AUTOMETER 2 INCH TACH 0-8000 $25
AUTOMETER 2552 2 INCH TRANS TEMP GAUGE BOX OPENED – NEVER USED -$25
BUICK MOTORSPORTS VALVE COVERS – PAINTED ALL BLACK $150
SEVEN GM BUSHING – NEW $5 A PIECE
SX EXTERNAL FUEL PUMP $25
AUTOMETER ISLOLATER BRAIDED WIRE TO RUN FUEL PRESSURE GAUGE INSIDE CAR $25
ATR DEFELCTOR INTERCOOLER SHIELD $25
USED GN FLOOR MATTS – DECENT SHAPE $45
JEGS 63002 STAGE CONTROL ROLL KIT WITH HARDWARE LINES AND FITTING – PACKAGE SLIGHTLY OPENED BUT NEVER USED $75
HEAVY DUTY STOCK IC HOSE KIT $20
PERFORMANCE FUEL SYSTEM ON RAIL FUEL GAUGE $20
TWO STOCK FUEL RAILS $45 A PIECE
STOCK DOGHOUSE PAINTED BLACK $45
70MM DOGHOUSE $100
STOCK CRANK – NEEDS TO BE CUT $150
AEROMOTIVE 11101 EXTERNAL PUMP (RED) $50
CROME MASS AIR FLOW PIPE WITH 14 INCH K & N FILTER WITH ATR RAM AIR CANISTER BLACK PLASTIC $75
TWO USED ALUMINIZED 2 ½ ATR PIT BULL MUFFLERS $40 PAIR
ONE PAIR GN SPOILER END CAPS $100
ONE PAIR CORNING LAMPS FOR GN $60
CASPERS FUEL INJECTION WIRE HARNESS $60
PLX EGT SENSOR MODULE $40
PLX M-300 AIR/FUEL RATIO $175
INNOVATIVE LC-1 WIDEBAND CONTROLLER WITH O2 SENSOR $150
HD WASTEGATE ACTUATOR PN#430819-39 $45
WINDSHIELD FUEL PRESSURE GAUGE 0-100 $25
VDO 2 INCH 0-30 BOOST,WATER TEMP AND OIL PRESSGURE GAUGES $50 FOR ALL THREE
CASPERS KNOCK GUAGE (BLACK FACE) WITH AUDIBLE SENSOR $75
THREE FUEL PUMP HANGARS SOLD AS IS $35 A PIECE
TWO TRANSMISSION DETENT CABLES $40 EACH
ONE POWER ANTENNA REPLACEMENT INSERT $75
DRIVER SIDE INNER FENDERWELL TURBO APPLICATION $50
PASSENGER SIDE FENDERWELL NON TURBO APPLICATION – NEW NEVER INSTALLED $40
AFTERMARKET TURBONETIC TURBO SHIELD $25
TWO WATER PUMP PULLYS $15 EACH
COMPLETE AFTERMARKET PIONEER STEREO SYSTEM WITH 6 CD CHANGER AND SPEAKERS THAT CAME OUT OF BPG CHAIRMAN SEAN RYDERS CAR THAT RIGHT THERE MAKES IT VALUABLE $50
GN STEERING WHEEL – NEEDS RECOVERING $50
Interested in the permacool oil/Trans cooler w/fan
Pictures please I will PM u my email address thanks
Also interested in the aeromotive fuel pump 11101 if it works and if pictures could be emailed
Thx will PM u on this as well
Thanks for all the interest guys I appreciate it. I have answered all PMs and sent pics, if I missed anyone please let me know.
If you are interested in the parts let me know and I will set aside and not take to BPG, otherwise I am taking the parts to BPG to sell at the event and will be loading up truck tomorrow.
Thank you again.
Are the Alky and wideband new or used? how used and everything working correctly? Can you send me pictures when you get a chance as well, no need for pics of the line lock obviously.
ISLOLATER BRAIDED WIRE TO RUN FUEL PRESSURE GAUGE INSIDE CAR $25 how much shipping to 33322 fl
Hi,
Shipping is $14. I found the Autometer 2" fuel pressure gauge that goes with it, if you want that for an additional $25 you can have it. If so grand total is $64.
My paypal is Buicksx2@aol.com
I am in BPG and can ship upon return if you like.
Hi,
Alky kit sold...........wideband is used. When it was in my friends Sean's car over 2 years ago it worked. I bought his car and parts and wideband not used since I bought it and all the parts. Let me know on linelock as I have it with me at BPG and if you are interested I will not put it out for sale tomorrow.
