Original_Owner
- Apr 15, 2009
As some of you know, I am trying to get together the money to get back home to the family in South America.
Due to the low prices that these cars are drawing at this time, I am going to try to sell these parts (one by one, or better yet the whole lot).
All parts are NOS unless otherwise indicated.
All reasonable offers accepted.
I am located in the Los Angeles, CA area.
Pat Campbell
626-664-7254
patcampbell1950@yahoo.com
Heavy Duty Intercooler Hoses
1984-1987 Engine Electrical Connector Kit
Transmission to Accelerator Cable
Doorpanel Plastic Screws
Console Applique
Radiator Bypass Hose
Adjustable Wastegate
Throttle Actuator Arm
Correct Lug Nuts for 1987 T-Tyype (5)
Spark Plug Wire Holders
GSCA Rear Oil Seal
Door Key Cover Kit (black)
Grey Valve Stem Caps (8)
Idle Air Control Valve
Air Intake Hose Clamps (black)
1987 T Fender Emblem
Enginetech Front Oil Seal
Throttle Position Sensor
Used AM-FM Radios circa 1987 (3)
Used Powermaster Brake Assembly (complete)
Grey Seat Fabric (appr.1 square yard)
Rubber Trunk Molding
3.8 SFI Turbo emblem (2)
Supersoft Doorseal Kit
EGR Valve (used)
Underdash Brake Switch
Accelerator Pedal Pad
Cruise Control Bellows Actuator
1987 T Hubcaps (3)
1983 T Hubcap (1)
Wiper Lever Assembly (used)
Heater Fan Control Switch
Gas Filter
Floorshift Lever Handle (rubber)
?? Looks like a distributor (part # 25516915)
Top with Wires for above part
Headlamps H4651 (1) H4656 (1)
K&N Filter Cleaner Kit (used)
Accel 8mm Extreme 9000 Sparkplug Wires (black and silver)
Coil Pack and Base
Fuel Injectors - Stock (2)
Coil Pack without Base
Wastegate Control Assembly? (Part Number 1997154)
Echlin TPS (part number 2-19058)
Heater/AC Control Switch (part number 1987380)
Driver Power Window Switch
Passenger Power Window Switch (3)
Heater Control Vacuum Assembloy (part number 15-71389)
Another Vacuum Control without part number (defroster?)
Shift Handle (part number 22525558)
Another TPS
Turn Signal Switch (part number 15705308)
Sensor AS (part number 213-1520)
Headlamp Dimmer Switch (part number 1987383)
Pat Campbell
626-664-7254
Console Applique
GSCA Rear Oil Seal
EGR Valve (used)
1987 T Hubcaps (3)
1983 T Hubcap (1)
Gas Filter
Coil Pack and Base
Another TPS
