Who Needs 8
- Apr 5, 2004
Ok, I've had this exhaust leak coming from the passenger side of the engine. I thought it was the ATR(might be TH) Downpipe at the joint. So I bought a Lap Band Clamp. I had to cut it a little because of the wastegate, but I tourqued that bad boy down to 70 ft.lbs. When I got it on there, I knew that it wasn't going to leak. Started the engine . . . TICK TICK TICK!!!!
I'm very convinced that wasn't the source of the leak.
(In case you're wondering, I assumed it was the DP because I found some soot on the underside at the joint)
So, I'm guessing there's only two other places where it may be leaking: Headers, DP gasket at the turbo.
After all that, My question is this: On a scale of 1-10 (10 being the hardest, 1 the easiest) how hard is it going to be to replace the left header gasket. I've done this time and time again on different cars, I'm more or less asking so that I can plan out a day or two and maybe even arrange to do this in an Air Conditioned Garage (Highs have been in the 100's).
Second Question: What kind of gaskets do you suggest for Stock Headers?
BTW Here's what I'm working with:
Stock Headers
Precision GT 3255 Turbo
Tile External Wastegate
3" ATR DP (Might be TH)
On a side note: I need an air conditioned garage
I used to take the car over to my Dad's During the hot months because he's got A/C in his garage, but right now he has filled up his garage while he's been putting his '53 GMC back together (Bone Stock and Original Farm Truck).
Stock Headers
