I've been chasing down vacuum leaks as a result of high BLM's (140-141) at idle. Through several different detection methods I eliminated a few leaks. My BLM's rest at 130-131, but only with the PCV valve port on the vacuum block capped off. Once I re-connect the PCV line the BLM's climb. Can you guys tell me what this means and explain the relationship? All the other vacuum lines hold vacuum when I pull vacuum with a hand pump.
Additional info that lead me to suspect vacuum leaks as the cause of the high BLM's:
FP is at 43 line off
Stock MAF, 1 screen, no observed irregularities
Idle 02's around 750-780
02 sensor is heated and about 6 mo's old. No race fuel.
Vacuum gauge reads -17 at idle.
Cruise BLM's near 128 +/- 3
Thanks!
Thanks!
