What are you guys with ported heads and using Fel-Pro # 1200 intake gaskets doing about your PCV? I have to keep it working to pass CA. emissions. Is there a valley pan gasket for use with ported heads? Thanks
I made a partial valley pan. I cut the port seals out and just left a piece to go to one bolt hole in the center of the manifold on each side. It's only purpose is to block splashing oil from the PCV.
