chevellejoe
- Apr 2, 2010
Has anyone had this issue of sucking oil through PCV from intake? I have the stock intake gasket with valley pan. It started after I rebuilt the motor and fixed my low oil pressure issue. Now my pressure is about 20psi at idle and 48 at 2400rmp. Anyway I am getting tired of the smell of burning oil. I temporarily installed the pcv in the stock valve cover pass. side breather and it got much better. I didn’t want to install a catch can and have to empty it every so often; I just want to fix it right. I figure I will buy the TA low profile valve covers with the breather holes vertical and install the pcv on the valve cover.
