Sleeper1987
3.8L of Fun!
- Jun 11, 2006
Ok guys , First lets say i know i have the wrong PCV valve i have a duetsch pcv100 that was in the car when i got it i understand the correct number is pcv126. Anything wrong with the autozone valve?
second issue
I have a leaking throttle shaft seal, Is there a o-ring or something i can use to replace the oem parts and still provide a satisfactory seal? Im not able to order offline and would need to be able to find easy bad stipulation i assume.
Third my blm is about 144 when at idle is this something to worry about?
second issue
