ok so... last week i took the vacuum that comes from the pcv to the vacuum block off i plugged the vacuum block outlet.. and ran a fab'd up oil catch can breather everything was fine i drove 2 days no problem except for a hot oil stench...but nothing in catch can.. i read up on it here and some people say it is critical to have the vacuum sucking from the pcv to ventilate crankcase pressure..do i need to run the pcv to the vacuum on intake?? also i noticed it sucks very hard causing the pcv to suck up some oil... i noticed because i ran a clear silicone line and i see oil in the line...without getting on any boost.. i took the line off while car on and it sucks like vegas prostitute... so is it necessary to run the vacuum from the intake or can i run the pcv to a oil catch can breather and plug the vac block outlet??
