I have a check valve in line between the vacuum block and the PCV on the GN, I had always thought it was stock? But on my Iroc ('86 T-type) it doesn't have this valve. Right now I'm sure I need to replace that PCV because yesterday at the road course track I started spewing oil out of the passenger side breather BAD. So Can I get away with just a new AC Delco PCV or should I put in a check valve like the GN has? If I need a check valve, where would I be able to find the right one?
