trading t/a
I'm Angry!!!!!
- Aug 6, 2001
Trying to figure this out. Reset ecm runs fine for 5 minutes or so then pegs the blm's and it starts dumping in fuel like crazy.
Swapped MAFs =no change, disconnected translator =no change, checked all vaccum lines =no leaks, swapped chips and known good ecm =no change, checked grounds =all good WTF????
I'm locking the chip in open loop. INT-128 BLM-128. It says 128, but I can see and smell it's still dumping fuel. Slight push on the pedal it smoothes out and doesn't seem to be running that rich....
Now the fun part, this happened out of the blue, No knock in the motor and hasn't seen a lot of boost. I drove it to E-town a few weeks ago pulled into the lanes and sat for 1hr or so(E-town sux 2 many ricers) before the first run. Wouldn't start??? Cranks but no ignition. Let sit for another 1hr, starts up but runs like crap. Idle seemed to stay around 1700-2100 and wouldn't come down.
Next to check!
Few things I haven't checked/corrected.
1. Slight exhaust leak on X-over.
2. Haven't changed out the coil pack/module.
3. Haven't swapped TPS and IAC yet....
Next to check!
