I finally have the car back together and I recorded 4 Turbolink sessions last night. The weather was cool and the car only went over 190 at idle, but stayed around 168 while driving. I noticed 6-16 degrees of knock at about 3500-4000 rpms and the MAF was pegged at 255. It seems I get more knock at part throttle than full throttle at times. Right up until the MAF read 255, the O2 was low/mid 800s so I was getting enough fuel up until then. I also noticed the voltage would dip to 11.8-12.0 at times and then back up to 13.7. This is with a new 140 Amp Alternator, high amp wire from Casper's and belt.
I ordered a TH downpipe with kick out( I will sell when I get it) & extender chip from Ramchargers. Would it make sense to also get injectors? I was only making about 14-15 psi from the stock turbo when this happened.
