turbojimmy
Supporting Member
- May 26, 2001
I have a question (or a few maybe).
First, my never-ending basement project is coming to a close. I may even be able to get the GN to the track this year!
I took delivery of a Sony 57" HDTV (a WV600) yesterday. Picture is awesome, analog signal over the cable feed is a bit grainy but the cable guy tells me it's the twist on ends I used. Could be, but the digital channels are great. I'll have to replace them at some point. When I first wheeled the TV into position, it looked smallish in the 30 x 14 room, but once the furniture got into place it was fine - the "2x screen size" as a minimum distance advice is good. The next step up - a 65" - would have been overwhelming. I get dizzy watching this thing.
DVDs are crystal clear but they don't use the full screen even when I use the DVD menu to select "wide screen". But it's not a horizontal problem - it's vertical. I'm smart enough to tell the TV to use "full" mode, which is the full 16:9 aspect ratio, but there are bars at the top and bottom. The size of the bars vary with the DVD (actually vary with the AGE of the DVD). The Matrix for example, was very thin and wide. Monsters Inc. was nearly perfect, but still had thin bars at the top and bottom. Could it be because I'm using the analog RCA connections? The DVD player is an older Sony, and a bottom of the line Sony at that. It does not have composite video jacks but does have an S-Video jack. Will using the S-video output fix this? Or should I spring for a DVD player with composite video feeds (I'll do that only if it fixes this "problem" - otherwise the picture is great).
I thought I was pretty savvy on this stuff but this new TV is making me feel stupid. It turns out that all this time my 4-year old Sony amp (STR-DE825) has not been doing Dolby 5.1 - only Dolby 3/2. Every time I put a DVD in it would switch to 3/2 decoding and shut off the sub. The blue "Digital Decoding Light" would come on so I ASSumed it was doing things optimally. The Infinity towers were doing a great job so I didn't notice. Yesterday I bypassed the decoding in the amp and forced it to "Normal Surround" which leaves the sub on. Holy bejesus - all this time I though my sub sucked - turns out it hasn't been turned on. What a dope.
Anyhow, thanks for any tips.
Jim
Jim
