SignUp Now!You really should be changing that chip to a modern chip like Turbo Tweak and add an adjustable fuel pressure regulator and hot wire. I will bet that your 26 year old fuel pump is taking a dump. Woefully inadequate 26 years ago. Downright dangerous for your engine now! One simple test you can do is to rap your MAF while the car is running with the end of a screwdriver or wrench and see if the car stumbles. If it does your MAF is bad. You should also get a Scanmaster so you can see what your numbers are. Also DO NOT TRUST your stock boost gauge. Very rarely do they give an accurate reading!Thanks much for your reply. I took my 87 GN out this morning in the nice cool air and this is how it worked. From dead stop at WOT it did fine till 4000 rpm then it goes into a missing type situation till round 4800 rpm and hesitates to shift. After going into second the same senareo. This has been happening. There are no mods as I bought the car in 1989 bone stock. I put a K&n filter and bigger exaust and thats all. It has it's original chip (not the recall chip). The only other thing 18 years ago I cut the waste gate actuator rod and threaded both ends to make it adjustable. I have continued to back off the turbo to eliminate possible dentiation and adjusted the shift cable and put a new coil pack on but no differance. It has a digital dash so not much info from that. Tried to keep it as stock as possible but maybe I should install a boost and knock guage. Any sugestions would be much appreaciated. Thanks much, Tim.
Thanks much for your reply. I took my 87 GN out this morning in the nice cool air and this is how it worked. From dead stop at WOT it did fine till 4000 rpm then it goes into a missing type situation till round 4800 rpm and hesitates to shift. After going into second the same senareo. This has been happening. There are no mods as I bought the car in 1989 bone stock. I put a K&n filter and bigger exaust and thats all. It has it's original chip (not the recall chip). The only other thing 18 years ago I cut the waste gate actuator rod and threaded both ends to make it adjustable. I have continued to back off the turbo to eliminate possible dentiation and adjusted the shift cable and put a new coil pack on but no differance. It has a digital dash so not much info from that. Tried to keep it as stock as possible but maybe I should install a boost and knock guage. Any sugestions would be much appreaciated. Thanks much, Tim.What kind of issues are you having? Anything done to it to your knowledge? I live in the Harrisburg area, I know one or two people that may be able to help. I'm usually too busy to fix my own car or else I'd volunteer. I'd actually post on the MAGNA section to find someone too!
Sounds like a great start. I have a casper adjustable chip I had in it but did not think it did anything. Would a direct scan work. I have one I used on my 89 TTA only because a kid programed the lap top and made it work. Would have to learn it. Can definetly change the fuel pump and hot wire it. Were is the best place to buy the parts. I also want to put a new gas tank on it. Thanx!You really should be changing that chip to a modern chip like Turbo Tweak and add an adjustable fuel pressure regulator and hot wire. I will bet that your 26 year old fuel pump is taking a dump. Woefully inadequate 26 years ago. Downright dangerous for your engine now! One simple test you can do is to rap your MAF while the car is running with the end of a screwdriver or wrench and see if the car stumbles. If it does your MAF is bad. You should also get a Scanmaster so you can see what your numbers are. Also DO NOT TRUST your stock boost gauge. Very rarely do they give an accurate reading!
Both the casper chip and Direct scan are old technology. I would not use either. Get a Turbo Tweak chip and a Scanmaster or Power logger. Scanmaster is easier to use and does not require a laptop. You can get both at Full Throttle Speed among other vendors on this site.Sounds like a great start. I have a casper adjustable chip I had in it but did not think it did anything. Would a direct scan work. I have one I used on my 89 TTA only because a kid programed the lap top and made it work. Would have to learn it. Can definetly change the fuel pump and hot wire it. Were is the best place to buy the parts. I also want to put a new gas tank on it. Thanx!
x2 on tt chip and adj fpr and pump...then scanmaster, hotwire kit and so on and let the money spending and addiction beginBoth the casper chip and Direct scan are old technology. I would not use either. Get a Turbo Tweak chip and a Scanmaster or Power logger. Scanmaster is easier to use and does not require a laptop. You can get both at Full Throttle Speed among other vendors on this site.
You are on the right path, pilgrim!Thanks so much everyone. Am ordering Walpro pump and hot wire kit to start. Also need a boost and knock guages.
Installed new fuel pump and now ready to inslall hot wire kit. What is the easiest and best way to run the harness.
