I was looking thorugh some old Direct Scan runs comparing my improvement in mid-range peformance. I picked an arbitrary speed range and measured the time between the two points. In this case the time between 30MPH and 80MPH.
My best time so far has been 6.8 seconds. This was recorded on an 8.4@83 run in the 1/8 on pump gas and the mods in my sig.
I zero the run on the first frame that indicates 30mph and move to the first frame showing 80mph to get the time.
I have DS set at 18.2 frames per second but I don't think it would make much difference if the frame rate were different.
I was curious how that compares to others. What kind of 30-80 times are you guys getting on Direct Scan?
Come on whip out your laptops and post some times!
Charles Brooks
Charles Brooks
