forcefed3.8's
Buckeye Bullet
- May 26, 2002
I am helping a friend part out his TSL car. The car was built, made 3 or so passes, had engine troubles, rebuilt engine, has 6 miles since
Stage 2 off center 016 4.1 engine. Complete intake to pan. Champion fully ported intake raised runners, GN1R raised port heads worked by DLS, T&D rockers, DLS solid roller, DLS 3.625 crank, DLS rods, DLS CP 9.5:1 pistons, 1" added to a stock 14 bolt pan. 4.02 bore. Was sonic tested when bought years ago, plenty of wall thickness, stock front cover and oil pump, will bolt in place of a 109 block with no mods. The block has had a repair from a broken connecting rod. It was rail damage, was repaired correctly, and will cause no issues. $12,000 will consider selling the short block
RJC Racing 475 big intercooler $800
Aluminum driveshaft for turbo 400 3.5" $450
TH400 trans Rossler brake, RMVB, billet drum, built by Janis, will be looked over by Vince before sold $2000
Spare tire fuel cell for use with stock hanger $200
Moser 12 bolt rear spool, 3.73 gear, Aerospace Components dual caliper brakes $2200
15x10 Billet Specialties Street Lite wheels 5.5bs 28.5x10.5 Phoenix slicks $450
70mm TB with lever and TPS $250
Stock appearing Hemco upper, was for a stock TB, was opened up for a 70mm $150
All prices do not include shipping. Local pick up on engine and transmission preferred at 44039. Thanks. Will be adding more parts this weekend.
