You are right here. The cart is pulling by apllying force to the ground or belt. But in the original problem the plane is applying force to the air around it not the belt. IT WILL FLYKEVINS said:This theory doesn't work because you have a source outside the "Working System" relative to the movement of the plane and belt. Put that cart on the belt with a chain to the plane THEN you have the cart "inside" the Working System and the plane will NOT fly.
ks![]()
