Pics of Iphone covers
TT/Ameasap
The White Blur
I have been doing some browsing for a new cover and was curious to see your covers.
Heres a current pic of mine.
Here's mine
No no no, that's Ty's. This is Charlie's.
Subscribed.
Waiting on a custom die to try on a couple Buick related designs.
Actually, it's going to be something more like this
But cut into an existing cover, or cut into Talon Grip tape on top of a cover.
Tried it with the dividing line down the center of the arrow, but that was a colossal failure. Tolerances were too tight for such a small die.
Here it is.
This is Talon (gun) grip tape over a case.
My other plan to die cut an actual case probably won't work due to the small amount of material between the blocks. This grip tape is heat activated adhesive, so the thin areas should stay on for a while (hopefully).
This is my cover. Understated (and a better fitting cover - even though the same brand as the others)
Is this for the 4S or 5S?
It's a Rocketfish case for a 5S. This "smoke" color case is not the best fitting. The black case (the one I use) fits and works great. I haven't tried any other cases yet. Should work with any case with a solid back. Just the logo, especially, should work on anything.
I'm also going to try other adhesive material. Aluminum shim stock? Mylar? We'll see.
