That's awful, you should just give up now
. I wish I could tig that well, but I get so little practice with any welding that each time is like starting all over again. Oh, are you using 304 or 304L? The L will cut corrosion a lot down the road. Also, after you do whatever cleanup you intend, find a source of citric acid (www.mcmaster.com has it but they aren't necessarily the cheapest) and mix up a solution about 5% by volume (a gallon is 128 fluid ounces so about 8-10 fl. oz. per gallon) in tap water, heat it to about 150-170 F, and soak the tubing as best you can with stirring for at least 15 minutes. I usually do 3 hours just for overkill since it doesn't hurt anything. This will passivate the surface almost as well as the nitric acid commercial process, but it is safe and you basically have concentrated orange juice which you can pour down a sink when done. The solution is good for a few months, until stuff starts growing in it, so keep it around. This won't remove any of the bluing from the welding but will slow down future rusting.
I used a plastic storage bin from WalMart as my tank, and had access to a heated cabinet with a shaking mechanism (we built shaker incubators for biologists to grow cells in) so I used that for agitation and heating to 165 F, and I passivated lots of small water tanks and other things that we fabricated in the shops. It made the difference between rusting badly in weeks and barely rusting in over two years on the water tanks (aggressive distilled water in a 80-90% RH atmosphere at 98 F with water in the tank and splashes on the outside 24/7). For long pieces you can just cap one end with your purge plug and fill with the solution to do the inside. Fill and empty a few times over a few hours, then rinse with water. If you can't dunk a weld on the outside just prop it over the tank and soak a rag in the solution and wrap the weld. Dip a cup of fresh liquid and pour over the rag every so often.
Anyway, just some suggestions. The welding really does look nice already, and if that was your first test then by the end it will look spectacular.
[edit was fixing # of fl oz in a gal, sigh]
