First off you may want to do a search...this has been covered a 1000x's over...
The blocks are all the same, however, you will have to drill for a oil return from the oil pan itself. Some folk have been lucky and grabbed a 109 block and found a turbo crank in the block, however this is the exception and not rule. Some people have had good success will the N/A cranks in the 3.8, however, I would strongly suggest the turbo crank due to the fact it has the rolled fillets on the crank itself. Stronger and better than the N/A cranks. You will need different bearings, GM Headgaskets, Pistons, Rods, Pushrods, etc...
On a turbo buick engine, there aren't MANY parts that are interchangeable, but as a paradox, there are some that are...the blocks are the most common though...
Good luck on that Junkyard search....:tongue:
