Sinister CO
- Jul 15, 2005
Okay, so I've been scrambling trying to get the GN together and ready for Pinks All Out on 8/8. I finally took it out for a test drive yesterday, and it seems to be backfiring on me. I've read quite a few posts on here and have checked the cam sensor, MAF, and all that fun stuff. I have not tried a new coil pack though.
Anyway, on to some info about the car. It has the usual fuel upgrades, Walbro FP, adjustable fuel pressure regulator, and hotwire. It has 60 lbs injectors too. I have a commander chip and the fuel pressure line off is at 45 (per the chip maker). The chip calls for one screen to be removed from the MAF, but I've tried it both ways and I may be crazy but I think it runs better with both in. It's got brand new plugs and wires on it. The plugs were gapped to .32 if I remember correctly. I also have a new oxygen sensor on it (purple wire GM). The TPS is .4 at idle and the IAC counts are in the twenties.
I hope that covers most of the info needed. I have direct scan too, so I've attached a couple of files from today. The first is in the garage, putting some revs to it in gear. The second is going down the block, backfiring quite a bit along the way. I'm not really sure what to look for on there, but thought maybe some of you guys will notice something out of the norm.
Any help you guys could offer would be appreciated. Thanks a ton!!!
By the way, I'll be out this evening so if you have any more questions about my setup, I'll get back to you tomorrow.
