Here is what I'm thinking: It is generally accepted that if you contain the heat of combustion in the cylinder, you can utilize the heat to expand the gasses and create work (downward force on the piston). Transferring heat into the cylinder head, cylinder wall or piston pulls heat away from the expanding gasses and decreases the efficiency of the combustion process.
In some instances, it is desireable to pull heat away from components that tend to absorb more of the heat of combustion. (exhaust seats and exhaust valves as an example)
It stands to reason that avoiding the transfer of heat into these components will make the combustion process more efficient. As you stated, the piston has very little transfer path to shed heat.
In an engine the piston will reach an average temperature that it will maintain during any given operation condition. I have no data to support that my pistons are ever operating at a temp that contributes to detonation. If I am not experiencing detonation and not damaging the piston, pulling heat away from the piston using piston oilers will only increase heat transfer from the combustion process and raise oil temps. Why would I do that?
I might even benefit by raising the average piston temps so that they will not absorb as much of the heat of combustion!! Heat transfers faster when delta T is great!! I make this last statement with tongue in cheek. Intuitively, raising piston temps would not be directionally correct!
The only time I would consider piston oilers is if I had data that told me I was operating my pistons beyond their temps limits -or- that piston temps were contributing to detonation. In my specific situation, with the fuel I use and the operating conditions, I don't see either problem.
If I were concerned about piston temps, I would seriously consider a heat barrier coating for the piston dome, rather than continuously pulling heat out of the combustion process and raising oil temps.
No flames intended here.............but enjoying the discussion!
Nice post Turbodave, and I too enjoy the discussion
I have a few counterpoints and things for you to consider;
First, this whole heat thing I think is misunderstood. Yes, keeping heat in the chamber increases efficiency which would be great if you were concerned with brake specific fuel consumption since you can use more btus from your fuel to move the car forward instead of spitting them out of your radiator.
For drag racing though, we aren't really worried about that because we are not limited by the amount of fuel we can carry or add. Horsepower is not directly related to BSFC, case in point, turbo engines have pretty bad BSFC numbers when you compare them to N/A engines. The extra fuel is used for
cooling the chamber which enables us to stuff more air, and thus more fuel to generate more horsepower.
We may lose some thermal efficiency in the process, but the loss is more than made up for by the gain in air consumption.. Actually you can see this in two engines; one of which with a low bsfc, ., and one of them with a high bsfc and the high one generating more hp despite having the same displacement. One is more aerodynamically efficient at filling the chambers with air than the other despite maybe having to consume more fuel than the other per horsepower.
As far as piston temps go, you may not have detonation issues now, but you could if you wanted to. Raise the compression, raise boost, etc, you are going to raise the mean combustion temp high enough to eventually induce detonation. The thing is, the combustion chamber doesn't in practice induce detonation because of an average temp.
All it takes is one hot spot. In this case, if you keep raising the combustion temp, your piston would theoretically be the first spot in the chamber (not necessarily, and maybe just a contributor) to cross the threshold from detonation tolerance to detonation intolerance. It could just be a very big straw that breaks the camel's back. The rest of your chamber could be good for a couple more points of compression or a couple more pounds of boost without pushing the fuel past that point. There could be a little bit of liquid fuel left whose latent heat could be used to cool the errant exhaust valve. With a hot piston, some of that or all of that was used up cooling the piston. With an uneven chamber temp you now have sacrificed some breathing room in this regard.
Instead of coming up on the limits of your fuel because of one part, or two parts, wouldn't it be much better to hit the absolute limit because
everything was at the limit at the same time and to an equal degree?
Transferring the heat to the oil makes it manageable. You can always add oil coolers or oil capacity and take that heat that would otherwise limit your dynamic compression ratio and put it outside of the car.
And as far as heat barrier coatings go, I am really curious to see what kind of thermal conductivity reductions these thing show in practice. I propose a test of heating a non coated piston with say a propane torch held to a precise temperature, and then heating a coated piston the same way and then measuring the temp at the backside of the piston. I def. think coatings work but I would be surprised if they were capable of rejecting heat as efficiently and quickly as a liquid such as oil. The OEMs use of oil jets in addition to coating I think supports this.
Anyway great discussion I look forward to your thoughts
