- Dec 15, 2002
So I replaced as many bulbs as possible with LED and it's been great until this last issue with the front side marker lights.
They are 194 bulbs and my LED 194s have worked everywhere else so far. Initially they did not flicker because I had the factory flashers in, so I replaced both the flashers and I get all of the turn signal lights to flash except for these 2 small side marker lights. Damn, so close.
I have seen others post about adding relays but I'm curious where do you add these relays to possibly knock down the current draw even more?
