SignUp Now!You could have the LED wired backwards. I just did this install 2 days ago and my LED did not come on either. But it was due to me not having the ground connected... DOH !!!
But the red wire from the LED needs to be connected to the black wire from the LC1, and the black to ground.
BTW, what is A12 and A6? I know the blue and white go to ground, and they recommend a seperate ground lug from anything else, as it can cause interferance with the signal. The yellow is taped back if you do not have a gauge, as you stated.
Also, the PL turn on is very cool. Connect the laptop to the USB port, fire the SW up, hit F3, then click the Scanmaster button and check the WBo2 box, and immediately it switches to WB from LB... VERY SWEET
Mike
The led is polarity sensitve?
Dave, How does the rest of the wiring look to you? Are these the right pin connections?
A6 is the main power feed to the ECM (pink/blk) so you can tap it anywhere along that wire.
As for the two grounds, I've been told that the blue wire can go to any good chassis ground, and the white should go to the "sensor ground" which is D10 (blk/wht) black with white tracer.
The yellow wire is the NBO2 simulator, so it's generally not used for anything.
My Innovative directions said to use a switched power with at least a 5A fuse, do you think it is safe to run it off the power feed to the ECM?
I put a 5A fuse inline to an ignition terminal on the fuse panel, myself...
Just another opinion...
Mike
