Pronto
No amount of evidence will ever persuade an idiot.
- Dec 9, 2002
My friends and posters here have had plenty of discussions on plastic tank radiators. Many use them on Turbo Buicks, others have stong reservations. The all aluminum radiator choices that are "direct fit" are getting scarce. Even those "direct fit" seem to not be that direct. A local guru here that has a 9 second car and works for customers did an install on a GN that he has owned for years and recently sold. The new owner brought it to him and the two proceeded to install the "direct fit" that the customer bought. Well, this experienced TB guru and his helper took 5 hours for this install. He was pissed and will never install that brand again. So the choices in plastic tanks is small too. Rock Auto has a few on their website specific to the TB. You can also use the F body without the oil cooler and different location trans line and radiator hose locations. Not a huge issue but not "direct fit". I've looked at the other G body plastic tank radiators that could work and found the CU570 which might work. I don't know anyone that has tried that. Most plastic tank radiators I've seen are the Fbody. So the big question with the plastic tank radiators that we have talked alot about is can they handle the rigors of a TB. I have seen an all aluminum radiator that was pressurized by a blown head gasket that pushed combustion chamber pressure into the system. The end tanks bowed out but it didn't fail. So the question is how would a plastic tank radiator behave if hit with high pressure. Others worry the plastic will age and split or crack.
V8Killer had a B body plastic tank radiator hanging around. It was used and at least 5 years old. He decided to see what happens when you pump it up with shop air. The ambulance repair shop he runs uses 145psi in their air lines. He blocked off the outlets and gave it hell. All the time he was scared it would blow up in his face. This is what happened:
So V8Killer can't say exactly how much pressure was in the tank but clearly the aluminum bowed out. The end tanks did not blow off or split or crack. I can't say this is definitive evidence a plastic tank won't blow off or crack but I think it shows they can take a hell of a lot of abuse. Looking at new vehicles, all use an aluminum radiator with plastic end tanks. Everything from a putt putt to a ZL1 Corvette. If the OEM manufactures have enough faith in them surviving then they must be half way reliable. V8Killer and I have decided the plastic alternatives are not a threat to blow a tank. We think the more likely item that would fail is a hose under extreme pressure.
