I'm trying a new laptop based scantool and need a little help with my numbers. I'm breaking in a new motor so i didn't get WOT numbers, only about half throttle, cause I'm chicken! Here they are:
WARM ENGINE AT IDLE: ON THE ROAD HALF THROTTLE
LOAD - 33 LOAD -- 255
IAC --- 16 RPM -- 3725
TPS --- .41 TPS -- 3.84
INT --- 126-130 not steady! INT -- 154
MAF -- 4-5 MAF -- 6
BLM -- 113 BLM -- 111
BAT --13.4-13.7 BAT -- 13.9
MAL CNT --30 MALCNT -- 66
KNOCK RET -- 5.27
RICH/LEAN CNTR-- 255
O2 -- .972
OLD PA3 -- 12
EGR -- 100%
The numbers on the right are Max values. Can somebody tell me what all this means or where I can find out. This program doesn't come with instructions. I'm fimiliar with the TPS and IAC. The rest is Greek me!! The car doesn't idle steady, it goes up and down about 25 rpm, between 775 and 800. I'm running a Red's 93 octane street chip. I'm also getting a RICH flag intermittently. Fuel pressure set to 42 line off. Any help appreciated!
MAF -- 4-5 MAF -- 6
KNOCK RET -- 5.27
O2 -- .972
OLD PA3 -- 12
EGR -- 100%
