Please Help ID This Turbo
THE TE SERIES ONE IS A 62
WTF IS THE TA ONE. that is the first time i have seen a 4 bolt housing with the internal wastegate side.
surej
not shure but it looks bigger than a 62 too me. The turbine side is a clipped p trim the compressor side looks like a 63 or a 66. Take the housing off and meassure the wheel.
Scotty,
I think it's a 45, though I can't really tell the shaft size from the pic. It has a 6 blade compressor wheel unlike the 61 and 62, which look like 7 blades. The 61 has a slightly smaller trim TO4B turbine wheel and the 62 and 45 have a P trim. There's a little more meat left on the turbine downpipe flange on the 61s as compared to the 62s, 45s, etc. that use the P-trim. Take a look at some pics here:
http://www.gnttype.org/techarea/pictureguides/turboguide/TE61vsstock.html
http://www.gnttype.org/techarea/pictureguides/turboguide/TE62vsstock.html
http://www.gnttype.org/techarea/pictureguides/turboguide/TE451.html
Oh..I looked at your old 51 tonight..it still feels as tight as new. 129 MPH and no melting... :D
Thanks folks.
I think we can definitely conclude it has a P trim turbine which the 62, 63 & 45 uses. Like Kendall pointed out, the compressor side is using the 6-blade wheel, unlike the 61 & 62 but it does not have a 4" inlet like the 45. My guess is, like malibuick231's, a 63. I do not have the turbo but have an opportunity to buy it at a reasonable price. I am getting shivers thinking about slapping this puppy on :eek:
Kendall, thanks for checking out my 51. With the rep of this turbo has gotten, I can certainly understand the doubts when a seller says theirs is in excellent condition.
Originally posted by Scottie-GNZ
Thanks folks.
I think we can definitely conclude it has a P trim turbine which the 62, 63 & 45 uses. Like Kendall pointed out, the compressor side is using the 6-blade wheel, unlike the 61 & 62 but it does not have a 4" inlet like the 45. .
Scotty ,
You cant make a decision based on that. The TE 45 is normally sold with the regular TE housing , same as a TE 61, TE 44 ect....The cool housing Kendall has on his is the st time ive ever seen them with it.
Compare your unit to my TE 45 with the regular compressor housing
http://www.gnttype.org/techarea/pictureguides/turboguide/TE45.html
Good Luck
Damn, thanks Louie.
If the 62 & 45 both have the same turbine side, is there any difference in how they spool up? Will this be too much for my setup? +.020 3.8L, Champion Irons and matching intake, stock cam, FMIC, AC 9.5 32-3500 LU. I am not looking to push this setup to the max as I want to the stock bottom-end (ARP rod bolts & head studs) to live but I also do not want it to be a dog spooling up. Just looking for another 35-40hp over the 51.
surej
The 4-bolt is a T-3 from a turbo ford.
Really? I thought it looked more like the turbo off of a 79 Turbo Coupe, but I really don't remember what kind of turbine housing they had. I know the compressor bolted to the intake and the compressor inlet sucked through the carburator.
I had a T63E and it looked like the one in the picture. I have a 61 now and it isn't that. I have pics of the 61.
Damn, thanks Louie.
If the 62 & 45 both have the same turbine side, is there any difference in how they spool up? Will this be too much for my setup? +.020 3.8L, Champion Irons and matching intake, stock cam, FMIC, AC 9.5 32-3500 LU. .........a dog spooling up. Just looking for another 35-40hp over the 51.
I dont know if they both do have the same. Either way i dont think you will have a spooling problem with that converter. Although ive seen your car run and you might want some lag on the street.....lol:eek:
If you need a specific pic of the TE 45 let me know and i can work on that as my car is down right now.
Yeah - look at the center section, it is water cooled. Carbed Hot-airs have 3-bolt turbine housings.
I now have this turbo in my hand and maybe the following will help pin down what it is:
- It has a .82 turbine housing
- It has "3705-1" scribed on the bottom of the compressor housing.
TIA
