I am needing advise on my car. The guy I bought the car told me to bump the stall up to 3600. I have ran the car once and here are the results. I couldn't get the car to build more than 1 to 2 psi boost before it would push through the brakes. (all runs @ 20psi with 110 race gas) 10.5-11.0 on the wideband.
2.03 60ft. 90.76 1/8mi. 12.54 1/4mi @114.65
2.10 60ft. 90.82 1/8mi. 12.65 1/4mi @111.08
2.93 60ft. 91.50 1/8mi. 13.57 1/4mi @116.94
So my questions are should I bump the converter to a 3600 or should I just leave the converter the same and put a trans brake in it? The trans brake would enable me to leave at 3600 rpms wouldn't it? Thanks for any help and heres the info on my combo.
450rwhp @20psi boost.
Rebuilt engine with TRW .030 over pistons, head studs, main studs, billet center main caps, balanced. Ported stock heads and intake manifold. 62mm throttle body. Crane 214/210 hydraulic roller cam.
PT63 turbo, CAS V2 front mount.
Dual 340 intank fuel pumps, hotwire kit, 50lb injectors, accufab regulator, lubrant 100 octane chip.
Jimmys stage 2 transmission, precision 2800 converter, trans cooler with braided lines and a/n fittings.
Terry houston downpipe with cutout open
