My digital dash reads a slower speed than the actual. ITs fine from 0-20mph. But above that it starts to slow down. If it reads 50mph then i am going close to like 80mph. Scanmaster reads the same values as the dash.
It has done this ever since i have bought the car.
I had a rebuilt tranny put in from a well known GN tranny shop 3 months ago, and was assured i have the right speedo gear. So according to the shop the culprit has to be the rear end. And from a test drive i was told i had 2.73 gears from a monte carlo most likely (becuase of my cars past with a monte carlo owner).
Today i jacked the rear end up. Spun the rear tire 1 revolution and had a helper watch the amount of turns the drive axle made. The axle turned almost 3.5 revs aproximetely. This sounds like the original factory 3.42 gears.
So whats left? Vss sensor or speed buffer?
Any help would be appreciated.
