Please I Need Help
scrobbyd
Well I thought I was having a leak between my trany and my stall because I just recently had a shift kit and stall put in my GN so I pulled my trany and went and had the front pump seal changed. Than once I got everything bolted up and back in place, started my car and realized my problem was in the lines, they have several holes in them, so I pulled both lines out, what a mess. Anyway I would like to know how are what I can do to replace these lines.:mad:
5/16" hard line from any parts store, bend with a tubing bender. Best to use the old lines for a template.
About $4 each for the tubing. maybe $15-20 for the bender, another $20 for a flaring tool or so.
And an afternoon.
Thanks For The Quik Reply
If I bend to match old lines what is the easiest way to get them back in without removing the motor. Any advice is greatly appreciated. Thank You Very Much:confused: :D
