"87LimitedT", having had one exactly like that, I know the answer. The first picture you posted is an original GM plenum that was modified to enhance flow. This was done by welding a plate inside and the welds ground smooth. Also the round opening for the throttle body was often enlarged (62 mm.was a popular size). Of course, the part number is indeed the same as the plenum in the second picture ( which is a stock, unmodified unit) as they used stock plenums to begin with...
The result is not bad (see times in my signature with a plenum like that + a RJC Power Plate...), although there are now larger throttle bodies/plenum combos available...
Hope this helps,
Claude
P.S: You can use the "modified" plenum along with an RJC power plate without any drawbacks...
