SignUp Now!The bigger the plenum the better it looks good just watch the distribution its gonna favor the rear cylinders, if you want better distribution move the throttle body forward this will give the air a little more time to make turns and such, at 250 mph where do u think most of the air will end up?
I'm sure he is gonna use a power-plate to correct for that.
Ive thought about making a baffle inside to devert air off the rear?
I was going to make the shelf by skip welding on a lip to the base plate..What do you think about a inch long and kicked down slightly towards the center? Im not trying to set the world on fire like you guys are with your build LOL
