SignUp Now!the plate is designed to equalize the plenum shape , so if both the plate has to be on the top of the spacer , and yes it would need three gaskets and longer bolts
but from the maker of the plate he has FAQs on the powerplate
Power Plate FAQs | RJC Racing
and in that list
Q6. Can I run my plenum spacer with a plate?
Because of the wide assortment of spacers available to us it would be impassable for me to test each and every thickness of spacer. The spacer does affect the how the air flows through the plate so the flow distribution is hard to predict. In other words, not if you want it to work properly.
I don't know shipt now that thats out of the way.Question on the spacer and the power plate ,Dont you what the power plate on top of the intake and the 1" spacer or 1/2" spacer on top of the power plate,because the power plate would still equal the air flow in to the cylinders with the spacer on top because of the volume of air being force in,Because i have mine set up that way on my stage II motor. Like to know more on this thanks,maybe i have mine wrong on the set up.
