C CalgaryGN Member Joined Sep 27, 2002 Feb 3, 2005 #1 What si the stock throttle body/plenum good for ?? HP/et wise ? Also what kind of gains are expected from upgrading the throttle body and plenum ?
C charlloots SMO-CUM Joined Aug 1, 2002 Feb 4, 2005 #2 you should be good into the tens with the stock tb. you might want a rjc plate with your stock plenium. you can also go with a 62mm plenium,and have your tb opened to 62mm.
